When I move the potientometer the Hot and Cold temperature selector from hot to cold or vice versa it might take a month or more for the damper door in the HVAC to operate. This summer it stayed on hot and I got hot air for about 2 months even though I tried using the AC. When fall and then winter came I moved the control to full heat and froze to death until about 2 weeks ago when the damper finally went to heat. I do not know what do disassemble as the whole thing underneath seems confusing. Saw the post about disabling a damper to get more airflow. This does not seem to be my problem.
What do I need to disassemble and HOW to get to the blend door? Is it vacuum or electrically operated.
BTW I have a dual HVAC system and changing the heat cool pot changes the heat cool in the rear auxiliary unit so I know the pot is working.
BIGHANK
BIGHANK
