I have a 94 pontiac grand am and recently replaced the engine. put in a brand new water pump but did not change the thermostat because the mechanic said it appeared to be fine.
Ive noticed the temperature stays around the middle mark most of the time and when i let it sit to idle from cold, it heats up and the fan turns on when it reaches halfway. however, when driving, ill notice the temperature change from the middle mark, go up to right before the red, and then go back way down to the quarter mark. Ive seen it go from 260 degrees F to 160 in a matter of 30 or 40 seconds.
my best guess is that its the thermostat needing to be replaced but any other ideas from the more experienced folks out there would be greatly appreciated.
