JShakey
I am replacing the front suspension components on my 03 Montana, On the passenger side the nut holding the outer tie rod end to the hub assembly will not come all the way off the bolt. There is an 8mm head on the bottom of the bolt which i assume is for removing the nut if the whole bolt turns but it will not go past that ? What am i missing? The driver side did not have it.
