i have 2000 pontiac sunfire 2.2 ohv and the timing chain is little bit loose. I installed new tensioner but didnt help any with the tension,is the chain suppose to be little loose and also the cam gear is about a tooth off from the timing tab on the tensioner when the crank timing gear is at TDC but seems to run fine and no hard starts....Thx
