Timing mark shifting on harmonic balancer?
TOG1937
Member
Possible stupid question alert:
If the timing mark and the crankshaft key-way are in one solid piece of steel how could the timing mark be off?
Please see pics.
Thanks!
The failed unit is off our new to us 1966 Catalina Convertible 389 YC code engine.
The new one is from Ames Performance Part #: PN687
Picture on their web site shows an outer ring which should have a rubber layer bonding it to inner ring.
Correct, the hub that is keyed to the crankshaft and the damper are two sep pieces and bolt together, 4 pcs total assy counting the supplied shim and re-use of the original pulley.
