troubles gaining speed
Sleepersunfire717
Lancaster
when i hit the gas it gains speed but it lags in between switching gears other then that it runs fine both the engine and transmission are stock the transmission is automatic any thoughts
Was planning to replace both in the future but don't know where to look but i am looking for performance if anyone can recommend a good 2.4L i could build off of that would be great too
how many miles on the vehicle?
how many miles since the transmission fluid and filter have been changed?
did you check the transmission fluid level and check if it smells burnt?
never flush it, drop the pan, replace the filter and pan gasket, and refill
