Turn signal wiring
Socklord
Hey, my turn signals often don't work when it's raining really hard... They stopped working about three months ago, and never came back. I replaced the flasher, but no go. So, I have to check the ground, but don't know which wire it is, or where it connects. I have a 95 Grand Am SE 2.3L. Or if there's something else I should try, please let me know. Does anyone else have this problem?
you can find wiring diragrams in the chilton and hanes manuals. You did check the fuse?
I did check the fuse. It was fine. I took alot of headlight shit apart, and started tracing the wiring. I rewrapped a couple things, it's an old car.... my turn signals worked again. I can't call it bad wiring. Some stuff was wrapped with duct tape.... I don't know, it works now, so... Thanks.
In this car, the wiring diagram is at best inaccurate. I use it as a guide. And I have a Haynes. I can't pull codes off the car because it's a split year. I have to do things the old-fashioned way. Which is complicated, due to the fact it's a modern car. It must have been a bad ground connection.
