turn signal
albertglvn
my turn signal is flashing rapidlywhen I hit the breaks, suggesting a bad bulb. replaced bulbs fixed problem temporarily problem repeats after replacing third time, I took a look at the old bulbs and realized they were still good.. I replaced the board but problem persists. any suggestiona
check the contacts in the socket. They may be corroded or bent so they dont make firm contact with the bulb.
Hi everyone!
You have a ground problem.
Take off you right tail light assembly.
Remove the PC Board from the light housing.
Use care to not break the plastick clips when remoing the PC board.
Disconnect the PC Baord that holds the bulbs from the wiring connector.
Look at the connector on the PC Board. The middle one is black, corroded and the black plastic is partially melted.
Look at the connector end.
The connector is melted around that plug location and the connector is also black and corroded.
Use a small flat blade screw driver to clean the pin connection on the PC Board side.
