Upper control arm question
Grimjack
I have started to work on my 65 Lemans suspension. If you look at the upper control arms you can see that the mounting assemblies are different. I have an original style mounting shaft with bolts on the end (drivers side) and I guess the newer type with nuts on the end of the mounting shaft (passenger). Does anyone know if I can just make them both the same style mounting shafts without any issues?front end1.jpg
All the replacement shafts I see use the nut. So buy a new shaft.
