upper engine bolts.brakets
fisher85
crystal springs,ms
hi guys,this is in reference to a 2001 sunfire my daughter bought around spring of last year.she drove this car for most of last summer,but early last fall after not maintaining it as it needed it ran hot while sitting at her friends house.she didn't have the money to get it fixed like it should be so i bought it from her and found out that the only problem was that the head got warped.i had it remachined and have since put it back on with all new head bolts and such.the main problem is she had a friend of hers take the head and brackets plus other things off in order to check the head.what i'm wanting to know is does anyone on here have a diagram or something else that shows where the brackets,bolts and such go.i've never worked on any type of front wheel drive or even this type of engine,mostly v-8,straight 6 or v-6.any and all help would be greatly appreciated.thanks in advance.
also try google with these words "image 2001 sunfire engine"
ok guys,i much appreciate the info i received and it was very beneficial for what i'm doing.of all the places that i searched on i did manage to find quite a bit of info on autozones' repair section,should've thought to look there at the start.once again,thanks very much for your input and help suggestions.
Glad to help , these newer cars may look confusing - complicated but they just have more stuff in the way and it takes longer to assemble/disassemble .........thats all.;)
Doug in P.R.:cool:
