Something got knocked loose or disconnected. Check all vac hoses. If you can't find any that are off or cracked, try some WD40 sprayed at the junction of the intake manifold and the heads. If the gasket is bad, the WD will dissapear. Plug vac hose to brake booster to see if it has failed. All your rubber parts are now 26 yrs old.
