Pretzel9872
- Dec 21, 2024
I replaced the fuel pressure regulator in my 2004 Grand Am 3.4L and noticed the old one had a bit of tube on top. The tube had broken off at some point, and now I'm confused about where to connect it. I got some tubes for it, and I found a diagram for the right engine (below) showing how the vacuum lines are supposed to go. According to the diagram, I need to connect the fuel pressure regulator (7) to the MAP sensor (12). the problem is that the MAP sensor is connected via a larger tube to a nipple at point 8 (diagram says "To Transaxle," which I don't understand).
I've seen other engines like this in the videos, and both 7 and 8 had tubes going towards 12. What should I do?
I'll take pictures of my engine tomorrow when it's light out.
image source: Vaccuum Diagram: Needing a Vacuum Diagram; Where Can I Find One?
