smayfield
Hi... replacing the valve stem seals on my 2002 Aztek (GM3400 motor and heads are off the car). I'm finding the new seals are very tight, to the point that I can't push them into place. From what I've read, the recommended way to install these is to lube them up and hit them with a hammer and socket that fits over the outer ring. The old ones came off pretty easy with a pair of pliers. I don't really see that I can hit it too hard since they eventually will have to seat at the bottom anyway, but just wanted to see if anyone had any suggestions. Is this normal? The seals are part of an aftermarket gasket kit (head gasket is the main reason this engine is apart) and to the naked eye, they appear to be the correct size/style.
