Washer pump issue
va2ir
07 torrent, original owner, 30000 miles, (50000 km).
Since new, the washer pump does not work below 15F (-12C)
Fluid is the -45 green stuff. Not frozen.
There is a hose joiner on the left inner fender, near the tank, so I undo the connection, and use human air power to blow air in the lines, I'm able to blow whatever fluid is in the lines, and I can hear and see bubbles blowing into the bottle. So the fluid is not frozen. Seems like the pump itself fails when it gets to cold.
Anyone else see this?
Ian R.
why wasnt the pump replaced while still under warranty? Can you hear the pump running when the temperature is that cold, if not, replace the pump.
