Where can I find a blue print/schematic for a 2001 Pontiac Grand Am - front dash?
x_tonyanicole
I'm having rainwater dripping from the dash to my passenger side floor board.
Thanks!
Hm mm a schematic probably will not help you much.. If you have water intrusion it can be from a couple things ...Your a/c drain is clogged up or your windshield is leaking rain. Run the a/c on the car and see if you get water dripping outside the car behind the right front well bout a foot or so toward the middle of your car if not them the a/c drain is clogged (common prob). Provided your a/c blows cold. The other option is to run water down windshield and see if you can determine where it's coming form. The only other thing i can think of would be your heater core is bad but your carpet would have green or orange coolant under it. Hope it helps.
