I can tell you that the V6 G8's will have some minor issues with forced induction. The original engine had high Natural Asperation in mind when they started designing it. So the lubrication systems are better suited for that. I'd tell you that if you are looking to just build up power to instead, get a Cold Air intake, a full exhaust including downpipes, bigger radiator, a programer, and if you are daring do the cams and lifters, also use AC Delco Rapid fire plugs and some better plug wires, if you really have time and money for this project you could even rip into the block and do the bearings rods shaft and heads. those engines are suited for up to around 580hp natural asperation. Good luck in what your endeavours!
