I have an 02 Sunfire with 100,000 miles on it and it seems that all 4 motors are going bad. I have replaced the two on the drivers side with the $31.00 Dorman replacements from Autozone. A relatively easy job with the right tools. I did the rear first and then the drivers window. After doing the drivers window I could not get the rear window to move? I removed the panel and disconnected and reconnected the switch and now it will operate from the center console button but not the door switch. I am thinking its a failing switch? Any thoughts/suggestions?
Thanks in advance!!
Thanks in advance!!
