wiring part
scoppex
Hey i have a pontiac catalina 1963
Can someone tell me what this parts is called ? and if someone has a pic of how the 2 small wires inside is conected, that would be awsome :)
Hope someone can help
Robin From Denmark
What year is the car?
What are the two large cables connected to?
Many of the wires do not look original .
its a 1963 catralina the 2 large red cabels is going from the batteri to the starter, im not sure about the rest of the cabels :-)
Below is a link to a 1963 Catalina battery cable.
The positive cable does not consist of two cables.
I believe somebody replaced the original cable with what you currently see.
None of those wires look factory original.
In 1963 that plastic conduit was not used.
You will have to trace the wires to see what their function is.
Did someone add an alarm system or some other modification to the car?
thx for the reply but can you tell me what the box that i broken is called, il look into the wireing tomorrow :-)
I have no idea what it is.
It is not original.
You have to trace where the two black wires go.
i dont know it the picture i just added could help i have but on the ohm wire ?
Sorry, you have to trace where the two small black wires go.
I have seen alot of models haveing the same kind of box Im looking for with 2 Black wires ? E64D0E20-8846-4750-A3F4-896AAE088411.jpeg
That is the Horn Relay if I remember correctly, its been a long time sense I have owned a 63 Bonneville
He means the part to the left of the relay where all the wires are connected.
Looking on line all the original cars seem to have it, but I am not sure what it is. I will ask the 63 Pontiac expert I know and see if he knows what it is called.
In the first picture by scoppex it looks like the metal relay cover has been broken off the plastic, taking the relay with it.
I agree with Kraig1957, while the picture he posted may not be the exact part type (possible different year or Division) but the correct type of part.
Maybe my old memory isn't as bad as i thought. LOL
