TOG1937
Member
- Feb 4, 2020
If you are running YearOne 17x9" Snowflake wheels, what are you using for lug nuts or studs? The OEM Snowflake wheel lug nuts only get about 4 threads of engagement with the OEM length studs - NOT SAFE ! Need either longer studs or longer shoulder lug nuts to get sufficient thread engagement. There should be at least as much thread engagement as the diameter of the stud or bolt, in this case 7/16".
Thank you!
Thank you!
