1998 2.4L Camshaft Position Sensor Location
ericv1984
Age
41
Lacey, WA
The sensor that is mounted on the head above the exhaust manifold, is that the CPS? I circled it in the picture below.
Another question, what's the sensor that is located under the cover next to the spark plugs?
That looks like the part in the link to me.
Yep, I would say that is the coolant temp sensor. The first sensor you showed (in your OP) looks like the camshaft position sensor.
Thanks, that helped a lot. I couldn't quite see all the letters in the diagram so I blew it up and printed it out. With a pen I marked all the letters on the picture so I could see them better. And all the ones I didn't know, I looked in my repair manual and it looks like it's the "Oil Pressure Switch".
But my car has ABS so it might look a little different, not sure.
