Hi all so I own a 1998 pontiac sunfire GT with the 2.4L engine.
Basically my symptom is when at idle for awhile, it will start to over heat. When I start driving the airflow will cool the engine and be fine. Naturally I assumed my thermostat because in the winter time at idle it would never get up to running temp.
Anyway long story short I replaced my thermostat and put all new coolant in and bleed the system. But I still am noticing same symptoms!
So I felt like an idiot because I noticed my Cooling Fan not on while the engine is hot after all that.
I replaced the "Cooling Fan" Relay and the fuse is not broken. I also unplugged the connector that runs to the Cooling Fan and cleaned it out with "electrical contact cleaner" just so I could say I eliminated that factor, and fan still wont run.
I do notice when I start the engine it will spin the Cooling Fan over for a second or 2 then it comes to a stop, so thats telling me that there is still power getting there?
So I guess my question is what else could be stopping my fan from not working? Could the fan altogether be shot?
Thanks for any help!
