Hello new to the forum. I have a 68 Firebird that is in roller condition. It is a 400 4 speed car. The motor has been rebuilt and has a upgraded cam and heads. But has been sitting for 5 years. The wiring harness has been long gone and purchased new. The diagrams I have are conflicting.
From the wireing plug on the fire-wall the left prong.
Tan = Brake fluid warning
Green= Temp sending unit
Brown yellow=blower motor
Blue= oil pressure sensor
Purple=solenoid
yellow =starter
Now I have a fabric brown/red stitch stamped to a yellow with a steel prong Does this go to the positive side of the coil?
The oil pressure gauge in the car has a tube from the oil filter neck? No sensor to plug into?? am I missing the location or did someone drill out a sending unit to fit the after market gauge?
My goal is to have it run for basic moving around the garages and barn. with out pulling out the ATV and having a assistant.
Lastly there is no connections on the positive side of the battery. I take it the right side plug on the fire wall harness will have the connections to the terminal??
Thanks for any help. Been years since It was wired up no Idea whats what anymore!
Purple=solenoid
yellow =starter
