jmichael0522
- Feb 22, 2016
I have a 95 Trans Am that is running rough. Some times it idles around 500 rpms and sometimes it's around 1200 rpms. I just bought I a few weeks ago and it seemed to run good until I had a heater hose spring a leak. Since then when taking off, it kind of sputters then it goes. A couple of times it has died on me while driving and I let off the gas. The check engine lite has come on a couple of times but is not currently on. Along with the problem came the problem of shifting issues. One day I was driving it to the store and it wouldn't shift. Now it will shift, but when you try to use the passing gear, it will not down shift. Sometimes when you try to get it to kick down, it cuts out really bad until you let off the accelerator. I am installing a cold air intake on it this weekend, because the current hose is tore where it fits around the throttle body. I feel like it may be a problem with the distributor and coil. As I hear this is a common problem with the LT1's. But I don't see how this would affect the shifting problem. The engine was rebuilt in 09, and according to the mileage on the receipts from the engine rebuild, it only has about 20k to 25K miles on it. Any advice would be greatly appreciated. I am eager to get this car running correctly since I bought it for my 16 year old son for his first car. I only have until July to get it right for him.
