I do feel resistance. I was concerned that the oil was flowing so heavily out of the cam thrust plate and no oil flowing on any lifter or push rod to rocker. Should I run drill faster and longer and should I see oil ever make it to the rocker area.
Looking at other posts with similar questions they don't always see oil. Do you have a pressure gauge?I do feel resistance. I was concerned that the oil was flowing so heavily out of the cam thrust plate and no oil flowing on any lifter or push rod to rocker. Should I run drill faster and longer and should I see oil ever make it to the rocker area.
You don't adjust Pontiacs with a running engine. If they have the stock bottle neck rocker arm studs the nuts are tightened to 30 ft/lbs.I have got the cam installed and am currently re-assembling and I am wondering if you have any recommendations on what I could use for an open rocker arm cover like something that would be used if I were adjusting the rockers to control the oil slinging.
They make clip on splash guards or cut open a garbage set of valve covers.Well I wanted to watch to be sure all rockers were getting oil and push rods were spinning.
Nobodies engine will run at 0 advance. You set the damper to 12 degrees before TDC on number 1and then drop the distributor in pointing exactly at 1 in the cap. Also make sure plug wire sequence is correct.I purchased a melling spc-7 cam (fn747b) (gm#9779068) and jpp-5614 nornda dual row billet gears and chain kit (fn749d) from Ames and replaced the worn out comp cam that was in my 1974 455 engine. I also put in new lifters. I purchased several other items from Butler to accomplish this task. So I attempted to start this engine a couple of days ago and of course I set engine to tdc and set hei distributor to fire #1 and lots of cranking and distributor movement it started for a short duration but really rough and I could see air being shot back up through the throttle body while running rough (sniper 1) that I used before this Cam and timing chain/gear swap.I used the standard timing (0) position on the Nornda. I was not given any information on the crank timing chain adjustable gear as to advance or retard if used with the spc 7 cam. I am wondering if these parts are compatible with each other. Is it possible the melling cam requires firing order change??
Yes but are they bottle neck screw in studs? The thread stops about 3/4 the way down and then the stud becomes larger in diameter.I think I see screw in studs and stock rockers tightened to 25 ft lbs. Also push rod guides. I assumed the previous owner had those screw in studs mounted in there by machine shop. I thought the factory studs were pressed in.
You were definitely on #1 cylinder when you installed distributor not #6?Yes, it is a bottleneck stud I took a picture of it but I can't send it to you on this website. Picture too large it said.
