That's with number 1 cylinder at 12 BTDC compression stroke? Number 6 cylinder should be on exhaust stroke. The rocker arm on the valve side on 6 exhaust should be noticeably lower than 6 intake showing its open.No # 6 cyl valve is basically closed. I can't wiggle exhaust until I get to 0. But I would say it is closed.
That's not what I'm asking. I'm sure valves go up and down. I'm trying to tell you with the engine at #1 TDC both #1 valves should be up/closed and #6 exhaust valve should be down/open. If #6 exhaust valve is closed when you are supposedly at 1 TDC you are Not at 1 you are at 6 TDC.Ok I turned the crank 1 turn and #6 intake went down and up (open close) . And #1 exhaust went down and up (open close)
The 1.52 from Competition Cams. Can you post a picture of a rocker arm stud?I just verified that I am at TDC and also damper line is in correct position. Well we tried another initial start and no run so we backed off the rocker arm nuts 1/2 turn tried start and it rough started so we backed off another 1/4 turn and it started and ran alot better but still kicking back a little air fuel out the throttle body. So we think it would be best if I moved to the rockers you told me about earlier some kind of a roller tip rocker. So what would you recommend in the way of rocker arms 1.5 1.6 roller tip? I assume the bottleneck studs will be useable for new rockers.
We think the new GM lifters may have caused all of this situation.
I have an android 13 phone. It's shows as a QR code. When I click on it the only image is a QR code. I use another phone to scan it and some illegible code appears.I did post a picture of the bottleneck 3/8 stud. The picture is the QR code post 37. I used my iphone to create qr code. I checked it and it worked for me. Let meknow.
