73catalina
- May 7, 2013
Hey guys, I'm driving a 73 Catalina with 400 engine.
I was having some coolant leakage from the timing chain cover to the inlet manifold ( there always was a little stream of coolant inbetween the cover and manifold). Last week I changed the gaskets from the cover, waterpump and I changed the little rubber donut. I was so happy because when i drove small distances the manifold was still dry. Just about yesterday (after a longer drive) I saw some coolant on my inlet manifold in that little ditch like place just about an inch behind the timing chain cover. I saw a drizzle of coolant coming from the carburetor side instead of the timing chain cover side. Thankgod.
My guess is that the coolant is slowly leaking out of my inlet manifold (near the carburetor) towards the lowest place on the manifold (that little ditch like place behind the timing cover) have you guys ever heard or seen something like this and what is your guess?
The timing chain cover is 100% dry so that cant be the problem.
I hope that you guys can give me a hint or tip.
Greetz,
Michiel from the Netherlands
Greetz,
