Roadrunner
your map sensor is connected to your intake as a rubber hose coming from it there should be 3 wires connected to it when you replace it you need to disconnect the negative side to your battery put the new 1 and then reconnect the negative.. after that your engine light may come on if it does disconnect th?e battery again wait 30 minutes then reconnect
