msmith1956
I've noticed that every once in a while that after stopping, and turning the car off, the radio doesn't turn off when I open the door. When this happens, the door lock will actuate immediately when you press the button instead of chiming for a delayed lock. I was thinking I might have a door jamb switch that needs cleaning/replacing, but I don't see one in the door jamb area. Is the switch integrated with the door latch, or door handle on this car? I have found the if I get out of the car, close the door and reopen it, the radio will then shut off, and door lock returns to normal. Any suggestions for what might be causing this?
