Hello all, so I have a pretty big problem, I decided to try installing a push button start in my 99 sunfire. I kind of winged it when it came to where to put the wires as I haven't done much for electrical mods other than stereos. Needless to say, there is a set of 3 wires just below the ignition where the key goes (Yellow, black and white) I stripped these and was spicing one of the wires for the push start when it connected with one of the other bare wires. Now the car will start once then dies seconds after, I have no dashights either. I can hear a buzzing coming from the drl relay located in the inside fuse panel. The car will start once and die, but if I try to start again without turning the key back to off, it just cranks without starting.
Learned my lesson to leave electrical mods to professionals, but need to have my car running for work monday! Any help at all will be greatful, going to pick up a new relay for the drl and fuel pump tomorrow, but not sure either will help.
I am quite stressed over this as I don't want to spend more on the car than its worth
Please help!
Please help!
