russell250
- Feb 21, 2014
i got a 2002 sunfire 2200 and having problems with the fuel pump not turning on. i changed the pump thinking that was the problem, no start|(used pump out of a known running car) the grean plug by the brake peddle inside the car i seen was burnt so i unpluged it and tryed the key and the pump worked so i replaced the green plug and it worked for a fue days then stoped working, changed the relay(tryed 4 different ones) checked fuse it was good(replaced anyway), got it going by flicking the key off and on seems like 100 time or more then the pump started drove it fue more days stoped working...no wires burnt around the computer and all conections underneath are dry and no damage .also it has a after market remote starter that dont work anymore(tryed unpluging it and no differernt)...can someone help me with this
