I know what the video shows but I still dont understand where your marks are located. Your sentence above seems to contradict itself,
" I meant that the bottom pointer/mark at 6, but the crankshaft is at 7." The bottom mark is the crankshaft. Please clearly state where the top camshaft mark is and where the bottom crankshaft mark is on your car. If the camshaft is not at 12:00 or the crankshaft is not at 6:00, with the belt removed turn them so they line up correctly. Please be aware that due to the different number of revolutions of the crankshaft versus the camshaft to fire all cylinders you can also have the camshaft showing 6:00 and the crankshaft showing 6:00. There are two complete rotations of the crankshaft per one complete rotation of the camshaft to fire all cylinders.
Thanks, Mel. I can understand why it sounds contradictory. Per your request to state clearly camshaft mark:
1) Cam SPROCKET mark (notch) points at 12:00 to rear cover plastic pointer.
2) Crankshaft mark (milled in U shaped mark on crank sprocket) is on crank, and currently has rotated to 7:00 position, as it was left there after removing timing belt.
3) That mark has to point to line up with matching milled U shaped point on bottom of engine, just above oil pan (see video, as I provided).
You say "the bottom mark is the crankshaft". No. The bottom mark(pointer) is on the ENGINE, not the flange of the crank sprocket. By "crank sprocket" I mean basically, the crank itself, as it is attached to a sprocket to receive timing belt teeth.
It is clear on that video. Please view it if you havent as it will be clear as day. Again, at about 2:05-2:20 into the video.
I am trying to put up a picture here but having difficulty. That picture will show 7:00 crank, and 6:00 pointer on engine.
Thanks for your continued patience with my challenging project.
