reble
Member
This is about the stock stereo/cd player that came with my 2008 Pontiac Torrent. The radio works fine, all the time. Sometimes when I put an audio cd or dvd in the player, the player takes in the disk, everything works fine. The dot shows up on the left side of the display. But the disk won't play period on any disk that I put in. The player just sits there and does nothing. I can pull the disk out. Also if I pull the wire plugs from the back of the stereo or pull the stereo fuse and let the stereo sit un-powered for a few minutes. Then put the fuse back in or replug in the wires to the back of the stereo. Then the player will work for a while until the SUV is turned off. Then when I turn the key on again the player acts up again. I tried putting a switch inline on the main power line to the stereo and mounted the switch in the panel so I don't have to pull the radio or pull the radio fuse. The switch doesn't help to reset the player. What now? replace the radio?
Steve
Steve
