I need a step by step how to time my engine. Its a 1975 350 Pontiac engine. I have a timing light and I know how to hook it up but I don't know the rest.
disconnect the vacuum line connected the vacuum advance on the distributor. Get a ratchet with a long extensions, probably need a universal joint and 9/16 socket. With the engine off mark the groove in the balancer with some white paint. THe timing spec should be on the decal on your fan shroud. start the engine and check the timing. if it has to adjusted loosen the distributor hold down clamp and carefully turn the distributor whlle watching the mark.
