92 Sunbird LE
Have Compression?
Doug in P.R.
Doug in P.R.
Glad you found the problem.Thanks for all your help and suggestions especially all the "check timing" reply's. The problem was the timing gear. All the nylon teeth were stripped off. Have parts on order and will replace everything. Thanks again.
I had a1977 Cutless 442 with the 403 v8 same problem it had not jumped timeThanks for all your help and suggestions especially all the "check timing" reply's. The problem was the timing gear. All the nylon teeth were stripped off. Have parts on order and will replace everything. Thanks again.
Did you have to drop the pan or how did you get the pieces out? I was hoping they will come out w g en I drain the oil.I had a1977 Cutless 442 with the 403 v8 same problem it had not jumped time
but i had heard of this happening to other cars, when apart i saw the nylon teeth
had broken off the aluminum gear, during a later job all the pieces had been sucked in the
oil pump pick up .
