Hey new here, I have 99 GT with 2.4 ov , did a total overhaul on the motor, all new everything in the motor and new fuel filter, all new sensors, Battery.
Runs down the road great, when cold start it idles at 600 rpm, but after it worms up it drops to about 200 rpm, does not die out when in gear, takes off from stop okay, when setting still in gear it is still at 200 rpm, when i replaced the fuel filter i had to replace part of the fuel line also,when i was bending it it kinked a little, Could this be a Fuel Pressure issue do to the kinked line???
I just can't figure it out.
If it had a wire hooked to it I replaced it on the sensors, cleaned all the throttle body, no vacuum leaks??????
it seems to have bad fuel mileage also, but haven't driven it enough to know
Help Please
Help Please
