i would start it and let it run for 10 minutes or so to circulate the fluids. one or twice a month is a good idea.
That is incorrect. Running for just 10 minutes will hurt the engine more.
You need to run the car (drive) for 15-20 minutes if you run it. If you cannot run it like that, Then do not run it at all. Running for just 10 minutes standing still will not peoperly heat up the entire drive train. Since it gets warm then you shut it off, it can build up condensation. This can get into fluids and damage things.
I put mine in storage at the end of October and pull it out in April. Been doing it since 2002 and have had no problems. If you store a car you need to do a few things.
Check tire pressure. I have the tires filled with nitrogen so tire pressure does not change with temp.
Pour some Sta-Bil in the tank and fill up tank.
Remove battery and place it on a trickle charger on a bench.
Place a box of baking soda in the car. Close windows.
If you have a problem with mice in the garage, You need to do a few things to prevent mice from using the car as a nest. A list can be found on the internet.
Cover car with a proper car cover.
This is only for storing a vehicle over the winter. There are other things that need to be done if you are storing a car for a longer period of time (years).
