Thanks, but the video shows a 3.4 and the 08 has a 3.9 and the thermostat housing doesn't have a bleeder, it must be somwhere else and i cant find it, if you can tell me where to look i'd find it most helpful.
The 3.9 has no bleed valve. On a cold engine is the coolant level about 1" above the seam on the tank? If not add coolant and let it cycle a few times till it maintains that level of coolant when cold. If that is not the issue a clogged heater core would be the only thing left.
