1980Esprit
Please help!
1) There are two things on my old intake I need to know about for my new one. There is this one thing which would be located on the rear passenger side that is cylindrical with single outlet on one side that is maybe 1/8-1/4 Outside width. other side has an L shape outlet with one going straight and one that is a 90 degree. Same width. I seen a fitting on the intake runner with the same width (Maybe these two connect? no hoses was on when bought with motor) There is also another fitting on the intake on the top near carb mounting (For vacuum? this is twice the size about). My new intake only has this thick fitting and not the small one. There is also no spot for this item to be put onto new intake.
2) Just beneath the water neck for radiator on intake looks to be a thermostat. Is it a thermostat? also right beside this is a weird looking thing that is black and unsure of what it is. The top part is plastic and the wrench size to put it on/off is 1 1/4 wrench( yes 1 inch and 1/4) What is this thing?
This is a 1972 intake so there is NO EGR.
P.S. I have two intakes, one is the original 1972 pontiac intake (400 ci). Second intake is an Edelbrock dual plane intake. http://www.summitracing.com/parts/edl-7156/overview/make/pontiac
ANY HELP IS VERY MUCH APPRECIATED. I WILL HAVE A PICTURE JUST TO SHOW WHERE THINGS ARE LOCATED. PIC IS PROBABLY GOING TO BE BLURRY SO ONLY REFFERENCE TO LOCATION. RIGHT WHERE THE RUBBER HOSE IS THE THERMOSTAT THING AND BELOW THAT IS FOR THE OTHER THING. IN THE BOTTOM LEFT HAND IS THE WEIRD THING WITH LITTLE NUBS FOR HOSES.
