Overheat warning
Cavell
Member
39
0118 code seems like a wiring issue. All the videos I saw said the open circuit should result in a -40f sensor reading. And I was getting a 140f reading. So the sensor was reading the low coolant temp properly. It was working as intended. Yes I am happy ac works and temp gauge works. But I think it is not fixed.
Cavell
Member
39
Drove about 1 hr yesterday. Went to a few stores. Used ac a bit. Turned ac off. Temp gauge still works. Speedo seems correct. Might change wheel bearing as constant stabilitrak warning is annoying.
21,621
214
63
Thanks for the update
Cavell
Member
39
3days driving now. No overheat issues. Temp gauge still works. Just poking the car gods by reporting all is well.
Cavell
Member
39
Picked up a used gauge cluster. Tach works now. And both speedo/tach do full gauge sweep on start. My old cluster never did that. Even the temp/gas needles do a little sweep.
