Wednesday afternoon when the rain let up, I decided to tackle the small amount of airflow out of the vents. Basicly took the whole bottom of the dash out to find the problem which didnt happen. I found that all the vacumn dashpots were working except the defroster one was a little slow. Someone else was looking for the problem before because they removed the blower fan and didnt reseal it. I gooped it up with some silicone and the airflow improved some but still not enough. I will flush the fan housing out with the hose soon in case the heater core is clogged with leaves and junk.( couldnt tell from the backside under the dash)
I was running the cooling fan off the blower wire under the hood for a quick fix when I bought the car in February, so I hooked it up under the dash to a key on Red wire that someone had hooked up the alarm back in the day when the car was new and now is long gone. Reminats remaining are the stickers, hood switch and the red minilight near the column.
I had to move the shifter lever while taking apart the dash a couple of times , so after it was all put back together, I went to go somewhere and put it in gear and nothing! ( gee I wonder why that ziptie was on the shiftercable to the trans was for) To hold it on cause the clip was missing?A quick wire job fixed that for now.
Friday early AM was a trip to Home Depot to get plumbing supplies and some other stuff. Got 2 small windows, 6 blocks , fittings and valves and 2 ten foot copper pipe. Rolled down the passenger window, put the pipe on the rear deck, and tied them to the window frame. I taped the end to the antenna and away I went. Just my luck it started to rain halfway back, so when I got back to Salinas I rolled up the window as far as it would go cause it started to downpour by then.
Thats all for now as the Sunbird adventures continue....... should get the Silverado this week cause the container made it to San Juan yesterday!
Doug in P.R.
